ianb Offline
#1 Posted : Wednesday, 17 October 2007 8:14:53 AM(UTC)
ianb
hi all, i have a 4 speed sandman van and the shifter linkage has a fair bit of play in it. can these be re cond to make them stiff again or is it just replace. also will a curved shifter from a bench seat model fit and work ok with bucket seats or will it foul anywhere. many thanks, ian.
vintageholden Offline
#2 Posted : Wednesday, 17 October 2007 9:45:45 AM(UTC)
vintageholden
cut the gear stick off curved one and weld it on the new linkages
not sure about fixing them
can get new from rare spares $300+
if you can weld ttry building up the linkages with weld, then grind down they get sloppy from use and wear out..
i did it t
Fred Offline
#3 Posted : Wednesday, 17 October 2007 11:17:07 AM(UTC)
Fred
Ours was a real mongrel to get into reverse and that was after the box rebuild so we purchased a new one and now it works like a new one which of course it should.
Tour Director Offline
#4 Posted : Wednesday, 17 October 2007 5:49:03 PM(UTC)
Tour Director
I believe that the components are heat treated to harden them so cutting and pasting might not be the way to go.I fitted a new shifter and avoided any problems. It feels like new.
adam PERTH Offline
#5 Posted : Wednesday, 17 October 2007 7:28:08 PM(UTC)
adam PERTH
the curved one , or "1 ton shifter", will work fine with your bucket seats.
just look silly.
A1 Bogan.
Duzty Offline
#6 Posted : Thursday, 18 October 2007 12:22:32 AM(UTC)
Duzty
I can do brand new aus 4 spd shifters for $302.50 or $396 for shifter and linkage kit.
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel f
adam PERTH Offline
#7 Posted : Thursday, 18 October 2007 9:07:54 AM(UTC)
adam PERTH
A good backyard way of fixin' these sloppy shifters is to keep the rear handbrake cable clips / brakeline clips (horseshoe shape) and jam em in there!
A1 Bogan.
adam PERTH Offline
#8 Posted : Thursday, 18 October 2007 9:07:54 AM(UTC)
adam PERTH
A good backyard way of fixin these sloppy shifters is to keep the rear handbrake cable clips / brakeline clips (horseshoe shape) and jam em in there!
A1 Bogan.
This page was generated in 0.088 seconds.
