Joined: 17/10/2025(UTC) Posts: 3 ![Australia Australia]() Location: Tasmania Thanks: 1 times
Hi all, I have a 75 HJ Monaro 4 door, High Compression 308, 4 speed manual Houndstooth interior, silver paint. The vehicle is in incredibly poor condition, via a WTF storage situation prior to my acquisition of it (parked under a rain tree in the tropics) I also have a HZ donor body in about as perfect condition as your going to find one and have rebuilt the small motor. All the compliance plates, original motor, revs checked etc.
A couple of things, firstly I know it is a ‘desirable’ car, for its specs, etc. I’m also ‘told’ it is somewhat rare, because it was built in the same year that 2 door Monaro’s were built, therefore it was a low numbers production for that year. I’d like a no B.S opinion of what I might be able to get for it? This car needs to be built nut & bolt perfect to realise its true value, which really means it needs everything re-done/restored (except the small motor). Happy to engage in discussion, about what I’ve got, not in the slightest bit interested in engaging in conversation with anyone trying to low-ball me.
I acquired the vehicle via a ‘good karma’ scenario, and stored it 8 years ago. I don’t think I’m going to get to it, and give it the love it deserves, so am ready to move it on.
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Why do blokes think they are allowed to swap the body tags? If the body is swapped with a kingswood body is it still a Monaro ? Personally Id want to keep the rts rails. I don't think its worth much its as cars are only original once. You could probably go and buy decent Monaro for what it would cost to restore a rusted out dunger and end up with a better car. Maybe Ive seen too many blokes spend lots of money on the wrong car. |
GM bleed us dry and run away. |
I’m fully aware of your point, Stevo, and DIDN’T imply that a body-swap was the ultimate goal, there is a good condition body on-hand, that will offer all the cuts required to bring this car back to life, I’m fully aware of the inherent value of fixing the original vehicle V’s swapping the body🤨
Thanks: 1 times Was thanked: 562 time(s) in 536 post(s)
HJ GTS sedan is by no means rare, there were about 4500 of them made compared to 606 HJ GTS coupe. Also HX GTS sedan about 2000 and HZ GTS sedan less than 1200.
Being a 5.0L car makes it more desirable than the standard 4.2.
No idea what its worth. Best bet is to put it out there for sale and see what you get. You'd be better off selling it and buying a completed car ready to use. Sell the HZ sedan body separate to, you'll probably get $2000 for it.
Note I just looked on FB, near me there is a really nice red HJ GTS sedan for sale for $100k, been on there for a little while. It is a 5.0L car but the more desirable for cruising TH400 M41 auto with aircon and power steer. SO that gives you an idea of what a finished one might be worth, although I reckon $100k is overpriced a little. |
Thanks, that’s a good answer, and I appreciate it. Regarding the rarity, just to clarify, my understanding is that it is a ‘low’ production number for 1975 builds, because they were building 2 doors that same year. (Wish it was a 2 door I had!)…. Unsure if it being 75 plated brings a little something ‘extra’ to the value, for the purists. I don’t doubt that 4500 were built, I guess the ‘rarity’ question is the 75 plate, for the reason stated. For the availability of parts, the 4 door body shape is a blessing, and I do have the additional shell for that purpose, and would happily part with both for half that number, which will be enough to free up collateral for other projects. Cheers
