basketcasebear Offline
#1 Posted : Wednesday, 4 June 2008 7:26:24 AM(UTC)
basketcasebear
hey yall,
I am wondering what causes "glazed bores", how do you tell if bores are glazed,,and is there any solutions, apart from rebuild,
thanks already
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
#2 Posted : Wednesday, 4 June 2008 8:01:22 AM(UTC)
Q. How do I know that my engine has a bore glazing problem?
A. You will notice one or more of the following symptoms:
1. Loss of compression
2. Excessive blow-by
3. Loss of power
4. Excessive crankcase pressure
5. Oil blowing out of breathers
#3 Posted : Wednesday, 4 June 2008 8:52:08 AM(UTC)
A cause is excessive idling, or constant running at fixed feed. That is why you run a new set of rings or new engine in by driving at varying speeds. City traffic is good for running in as the speeds vary a lot.
#4 Posted : Wednesday, 4 June 2008 11:47:44 AM(UTC)
basketcasebear
thanks john
thats probably the reason, too much idling,
bcb
ptpro
DOH!!!
#5 Posted : Thursday, 5 June 2008 10:41:41 PM(UTC)
I have heard that the rough (pardon the pun) but effective way to get rid of glazing in bores is to rev the engine and shake Ajax down the carby.
The Ajax scuffs the glazing off the bores.
You could be a little bit less butcherus and remove
#6 Posted : Friday, 6 June 2008 9:06:34 AM(UTC)
It's not purely idling, it's running at any constant speed for lengthy period, like cruising at 100k for several hours.
#7 Posted : Friday, 6 June 2008 9:06:34 AM(UTC)
Its not purely idling, its running at any constant speed for lengthy period, like cruising at 100k for several hours.
