#1 Posted : Friday, 15 February 2008 12:13:53 AM(UTC)
I have a WH stato that needs the brakes serviced, (new master, new fluid & pads all round) I would like to know if it is advisable to have it done by a pro & pay due to having ABS, or can I do it myself. Have done many a fluid/pad change over the years, but not involving ABS systems.
Thank's
Kevin
Edited by user Friday, 15 February 2008 12:50:11 AM(UTC)  | Reason: Not specified
#2 Posted : Friday, 15 February 2008 1:31:35 AM(UTC)
Was thanked: 229 time(s) in 205 post(s)
Hi Monaro202
The only 'pro' thing that needs to be done is the pressure bleeding of the system. Seems unusual that a WH Statesman should need a master cylinder at this age. Has the car done ridiculously high kms? Or has the fluid not had regular change
#3 Posted : Friday, 15 February 2008 1:31:35 AM(UTC)
Hi Monaro202
The only pro thing that needs to be done is the pressure bleeding of the system. Seems unusual that a WH Statesman should need a master cylinder at this age. Has the car done ridiculously high kms? Or has the fluid not had regular changes.
#4 Posted : Sunday, 17 February 2008 8:59:08 PM(UTC)
dont think the fluid has ever been changed, there is a hell of a lot of contamination in the fluid & the bowl leaks where it attaches to the cylinder body..
thanks
#5 Posted : Sunday, 17 February 2008 8:59:08 PM(UTC)
don't think the fluid has ever been changed, there is a hell of a lot of contamination in the fluid & the bowl leaks where it attaches to the cylinder body..
thank's
