eskimo_joe777 Offline
#1 Posted : Wednesday, 9 January 2008 3:26:24 AM(UTC)
eskimo_joe777
I went for r/w and one of the things i have to do on my old HJ van is the wipers because they stop where you turn them off instead of finishing the wipe and stoping on bottom. What can i do to fix this?
any help would be great.
Cheers Justin
#2 Posted : Wednesday, 9 January 2008 4:31:28 AM(UTC)
One of two things, does it still have the metal strap on the motor to the body?
If it does then the contact on the cam needs retensioning, not a hard job you need to pull the motor out and get into the large wheel. On the underside there is a set of co
BlaDe Offline
#3 Posted : Wednesday, 9 January 2008 6:57:18 AM(UTC)
BlaDe
even if it does have the strap check it is earthed properly as mine had the strap screwed down tight but it wasnt earthing at all so i sanded the firewall a bit more and job done
Blade
#4 Posted : Wednesday, 9 January 2008 6:40:15 PM(UTC)
Was thanked: 229 time(s) in 205 post(s)
#5 Posted : Wednesday, 9 January 2008 8:27:32 PM(UTC)
Thanks also fellas. In the search for a neater firewall I took off the little strap. Guess what happened, that will teach me to mess around with things that work. Good advice guys...
#6 Posted : Wednesday, 9 January 2008 8:27:32 PM(UTC)
Thanks also fella's. In the search for a neater firewall I took off the little strap. Guess what happened, that will teach me to mess around with things that work. Good advice guys...
