sly376 Offline
#1 Posted : Tuesday, 26 September 2006 7:54:32 AM(UTC)
sly376
Hey boys how you all doin? I was running a hydrolic setup in my 351 clevo & everyone has told me that the solids are much better power wise but require a bit more maintanance etc. I'm tossin up between the Crane F238 & the Crane F246 cam, it's a street car but I want some more grunt, my last hydrolic had 580-590 valve lift & was a bit of a dog down low & really should have been pulling harder. I want a bit more torque down low & want it to scream up hi. I currently have 2v closed chamber heads (relieved) with 4V valves 58cc chamber which made a comp ratio of 10.25:1 how hi can you go with the comp ratio on these cast heads without pinging? Want to do a bit of porting too aparently these 2v heads don't need that much to flow like crazy & maintain velocity, I'm getting new roller rockers & also wondering about these roller lifters & roller cams???? Can you run these on standard Cam bearings? Any idea what it costs to setup these heads properly? I'm hoping for about 450hp at the flywheel or a bit more if possible. Is it really worth buying AFD or CHI heads for $3000 plus (that hurts!)
XB351 Offline
#2 Posted : Wednesday, 27 September 2006 1:11:05 AM(UTC)
XB351
If your 2V's are any good? 450 is achieveable. Use the F238 it's a great street cam. My mate has one in his 351 2V, makes 252rwkw. The torque is very nice.
His engine setup is :
351 10.5:1 comp
2V closed chamber heads (4V valves)
2V weiand xcelle
sly376 Offline
#3 Posted : Wednesday, 27 September 2006 7:29:19 AM(UTC)
sly376
Hey buddy thanks for all that info I'll be going for the F238 Cam shaft. The setup I have is as follows
351 10.25:1 Comp
Yella Terra Roller rockers
2v Closed chamber heads (chamber has been opened up a bit) 4V valves think they are 2.19'' & 1.76"
2
XB351 Offline
#4 Posted : Friday, 29 September 2006 10:03:03 AM(UTC)
XB351
sounds good the F238 will work well. With an F238 don't you don't run out of legs with 4.11's ;) 4.11's should see you around 200kph. Since your manual though you have a shorter 1st gear. Which would suit the 3.5's :)
sly376 Offline
#5 Posted : Wednesday, 28 March 2007 6:25:42 PM(UTC)
sly376
Hey XB351 just wanted to let you know I ended up doing up a set of 2v closed chamber heads, ported polished, All quality Crane cam valve train & I ran a F238 cam. I had my first dyno run yesterday & made 249.2kw rw or 334.2hp but the guy did not want to t
XB351 Offline
#6 Posted : Sunday, 15 April 2007 10:13:40 PM(UTC)
XB351
Good to hear. It's on the money power wise too, so the heads must be good ones.
Edited by user Tuesday, 17 April 2007 3:26:46 AM(UTC)  | Reason: Not specified
#7 Posted : Thursday, 19 April 2007 3:46:56 AM(UTC)
WOW,
this is all the info i have been looking for!
have you been back to the dyno yet mate?
sly376 Offline
#8 Posted : Thursday, 19 April 2007 7:33:29 AM(UTC)
sly376
Have not been on the dyno yet but I can say she feels much stronger with the jets & power valve :) heaps more responce down low & mate she screams up to 6500 real fast now. All I need now is a good clutch kit. I'm running a ****ty performance RPM clutch t
XB351 Offline
#9 Posted : Thursday, 19 April 2007 7:23:08 PM(UTC)
XB351
use a h/duty clutch from an F series truck or you can spend heaps and go an extreme clutch from HP in a box.
sly376 Offline
#10 Posted : Friday, 20 April 2007 8:04:11 AM(UTC)
sly376
cool, would you say the finger type is the go or the normal type pressure plate?
XB351 Offline
#11 Posted : Monday, 23 April 2007 12:00:33 AM(UTC)
XB351
I'm pretty sure the one we used was normal a pressure plate type.
#12 Posted : Monday, 23 April 2007 9:53:45 AM(UTC)
sly376 Offline
#13 Posted : Thursday, 26 April 2007 2:12:01 AM(UTC)
sly376
Hey buddy I'm in NSW Sydney. Mate it's not cheap setting up a clevo. I spent about $4500 on my bottom end, that's parts & machining work. With the top end heads set me back over $2000 & then the rest of the valve train parts etc another $2000. I built the
XB351 Offline
#14 Posted : Thursday, 26 April 2007 10:58:03 PM(UTC)
XB351
XYSedan : for similar $ you can do a Pavtek engine. Their website appears to be offline at the moment :(
#15 Posted : Friday, 27 April 2007 9:53:58 AM(UTC)
hey guys,
hrmmm thanks for that info,
but i was not expecting that sort of money!
rather know then not though...
its tempting to just go down the pavtec track... as XB351 said
got her dynoed yet mate?
sly376 Offline
#16 Posted : Friday, 11 May 2007 6:40:34 AM(UTC)
sly376
Hey XB351 what are these pavtek engines any info?
XB351 Offline
#17 Posted : Sunday, 13 May 2007 7:25:48 PM(UTC)
XB351
Pavtek builds what I guess you would call crate engines? They range from 300-600hp+.
Edited by user Monday, 14 May 2007 4:32:26 AM(UTC)  | Reason: Not specified
#18 Posted : Wednesday, 13 June 2007 12:22:07 AM(UTC)
Hey sly376,
hows the engine going?
any progress?
This page was generated in 0.115 seconds.
